mkhan Posted November 12, 2011 Share Posted November 12, 2011 am looking for an efficient way to make dull ss material for building exterior scene in vray. . tried using glossy reflections with standard max material. doesn't always work well. INterior scene, results are good. exterios the same material looks too flat. any help.. Link to comment Share on other sites More sharing options...
Matt Sugden Posted November 12, 2011 Share Posted November 12, 2011 With any highly reflective material a key factor of convincing results is the subject mater of the reflections themselves. Which might be why interior results look good but exterior results are not as convincing. Internally you will probably have a very convincing controlled environment for the reflection, externally however you may not depending on how your scene is set up? Perhaps try adjusting your environment and you should see wildly different results from your SS material. Link to comment Share on other sites More sharing options...
M V Posted November 14, 2011 Share Posted November 14, 2011 Bewdy is right. I would use a high res environment map or a photo of the site if you have one. Link to comment Share on other sites More sharing options...
