izrut Posted August 31, 2004 Share Posted August 31, 2004 Hi U all Mental ray interior siene. Lightning: Sun Light - mr directional Sky Light - skylight + area light on the windows Rendering: GI+FG The Lightning is almoust there...but I think something isn't right... Any tips and advices are appreciated! Link to comment Share on other sites More sharing options...
bobmaxer Posted August 31, 2004 Share Posted August 31, 2004 its a good rendering, may be the scene lacks contrast, try photoshop to adjust the contrast Link to comment Share on other sites More sharing options...
kicks Posted August 31, 2004 Share Posted August 31, 2004 Link to comment Share on other sites More sharing options...
izrut Posted August 31, 2004 Author Share Posted August 31, 2004 Hi U 2 Kicks I've been experimenting different variations of control over the The Skylight...I've tried to put just Area Lights but the FG is not working well without max skylight...actually I did check out if vray tactik with area lights is working within the mental ray...but something isn't just right. Yes, I did use exposure control though I don't like it...I didn't have much time to spent on this siene.it was just a quick test and I couldn't afford many test so I just activated exp ctrl to hide some artifacts.... Personally I prefer to use the light enerjy in the siene - no exp ctrl p.s. Here is the siene if some one is interested in the settings...download Link to comment Share on other sites More sharing options...
Harjeet Singh Posted August 31, 2004 Share Posted August 31, 2004 Hi there, very nicley detailed model. the rendering looks dull but soothing. I feel the first image camera is a bit too high. good work! my regards Link to comment Share on other sites More sharing options...
joske Posted September 1, 2004 Share Posted September 1, 2004 yes loose the skylight, it will only slow down your rendering time (try a render with only the skylight to see what it acually does... you'll see not very much) loose the exposure control also it will smooth things out sometimes, but it will mess with the colours and contrasts of your scene the chairs for instance will have a much better 'wood feel' if you turn of the logaritmic exp control Link to comment Share on other sites More sharing options...
izrut Posted September 1, 2004 Author Share Posted September 1, 2004 10x joske I gave me a brilliant idea...I'll do some tests and discuss it later thank U again! Link to comment Share on other sites More sharing options...
izrut Posted September 1, 2004 Author Share Posted September 1, 2004 daylight is killing me.... Link to comment Share on other sites More sharing options...
abicalho Posted September 1, 2004 Share Posted September 1, 2004 I will post the pictures I took today at home... Several shots of the same room with Daylight coming in and our Chinese Lamp on and off. I took them using exposures 8.0 to 2.8. None of them looked good because the Sunlight is simply way too much strong. It just showed me that I'd never ever use Daylight in a shot like that, I would use tricks (as I'd use in Photography) to reduce/adjust the sunlight to nicer results. I'd challenge you all to do this test too. I'll get the pics online tonight and post them here. My camera is currently in the tripod sitting at home because I want to make sure I take the same pictures at the end of the day (No sun), at night, and tomorrow morning (hoping to have some fog here). Sorry I didn't give you an answer, but I hope it helps, Alexander Link to comment Share on other sites More sharing options...
izrut Posted September 2, 2004 Author Share Posted September 2, 2004 I would like to ask U all - write down the kind of lightning u r useing for interior daylight and shader settings (walls, foolr, ceiling..may be glass ) when useing mental ray renderer Link to comment Share on other sites More sharing options...
izrut Posted September 4, 2004 Author Share Posted September 4, 2004 Is this convicing daylight? *The seine is taken from a speed vray test...remade in mantal ray... Link to comment Share on other sites More sharing options...
joske Posted September 4, 2004 Share Posted September 4, 2004 drop us the link for the vray renders for reference pls would be great to compare and have a stab myself at it... Link to comment Share on other sites More sharing options...
izrut Posted September 4, 2004 Author Share Posted September 4, 2004 joske, here it is --> Vray Reference Bitte Link to comment Share on other sites More sharing options...
