3dvizual Posted November 14, 2011 Share Posted November 14, 2011 Hi. How do I automaticly add double the amount of vertices to a plane. Is there a modifier for doing so or is it manually, one at a time.? Link to comment Share on other sites More sharing options...
datacrasher Posted November 14, 2011 Share Posted November 14, 2011 Don't convert down just add an edit poly or edit mesh then you can go back to your plane and add more segs to your plane once you have the right amount then you can collapse the stack down to whatever you need Tony Link to comment Share on other sites More sharing options...
3dvizual Posted November 14, 2011 Author Share Posted November 14, 2011 OK. what if I have converted the plane to an edit. poly.? Link to comment Share on other sites More sharing options...
plastic Posted November 14, 2011 Share Posted November 14, 2011 Try the tesselate modifier... Link to comment Share on other sites More sharing options...
datacrasher Posted November 14, 2011 Share Posted November 14, 2011 No the The Tessellate modifier subdivides faces in the current selection. It's particularly useful for smoothing curved surfaces for rendering, and creating additional mesh resolution Go to your edges, turn on edge faces select one side of your plane and then the other depends which way you want the segs to go and use the connect box and then click How many segs you need once complete then click ok Link to comment Share on other sites More sharing options...
