3dvizual Posted November 14, 2011 Share Posted November 14, 2011 Hi. I would like to create the effect of snow on a plane (roof top). (Like a blob-mesh) How should I create this the easiest way from a plane (maybe extruded plane).? Link to comment Share on other sites More sharing options...
datacrasher Posted November 14, 2011 Share Posted November 14, 2011 (edited) just add a snow texture to your roof. if you want it to be snowing then create a snow effect under the geometry drop-down menu particle systems in the top view once you have done that use the start time set that to 0 and then put your life time to whatever you need the length of your animation. change your viewport count too about 200. the problem is with the snow effect then they look like stars when you render it up.. i would use the super spray to create snow or even the blizzard Edited November 14, 2011 by datacrasher Link to comment Share on other sites More sharing options...
3dvizual Posted November 14, 2011 Author Share Posted November 14, 2011 Hi Tony I downloaded the plugin pwrapper and made a snow particle system. It worked out great. Link to comment Share on other sites More sharing options...
