Graphite Posted November 16, 2011 Share Posted November 16, 2011 Hey everyone; Have to be what seems a simple question, but its alluded me for quite some time. I used to work for a firm that had a shortcut key programmed into max that moved the transform/move/scale gizmo along the the Top, Middle, and bottom of a selected object, wether this object was an entire model, or down to an edge face. Would anyone know how to set this up OR, knows what the Plugin or script that might have been used? Thanks -n Link to comment Share on other sites More sharing options...
Cyberstyle Posted November 16, 2011 Share Posted November 16, 2011 In the Hierachy utility panel (next to your modify tab), you can shift the pivot point anywhere you like. Just click on "Affect Pivot Only" and move it, or even create temporary working pivot points etc... There probably is a script out there that has more features, but the above works just fine. Link to comment Share on other sites More sharing options...
Graphite Posted November 16, 2011 Author Share Posted November 16, 2011 Yea; I'm just looking for a way to use a short cut key to quickly move between top, bottom, and center pivot locations Link to comment Share on other sites More sharing options...
datacrasher Posted November 17, 2011 Share Posted November 17, 2011 (edited) You can create your own sortcuts in max go to customize, customize IU (user interface) and create shortcut (hotkey) Use the Group and Category lists to find the action for which you want to create a shortcut. Click an action in the Action list to highlight it. In the Hotkey field, enter the keyboard shortcut you want to assign to the selected action. Note: If the keyboard shortcut you enter is already assigned to an action, that action's name will appear in the Assigned To field. Click Assign. Edited November 17, 2011 by datacrasher Link to comment Share on other sites More sharing options...
