gustav_gans Posted August 31, 2004 Share Posted August 31, 2004 hi guys! this is my first try on GI. the image should appear as computer generated with a touch of reality. the main problems are the glass texture and over all contrast of the image. all the C & C are highly appreciated. regards gustav by the way, i m using 3dsmax 6 Link to comment Share on other sites More sharing options...
Tom Hamelrijckx Posted September 1, 2004 Share Posted September 1, 2004 Hi, it ain't that bad, though it looks weird the first time. I would say, the furniture on the inside seems a little bit self-iluminating. Why not aproach the whole as a miniature model? Put some lights on the inside (Marklin look-a-like) and use some DOF? Reduce the number of bounces as well and get more contrast that way on the sides of the building... Link to comment Share on other sites More sharing options...
Harjeet Singh Posted September 1, 2004 Share Posted September 1, 2004 good start, go ahead experimenting. Link to comment Share on other sites More sharing options...
gustav_gans Posted September 1, 2004 Author Share Posted September 1, 2004 thx for the tips! but sorry for the question: what is DOF? any hints about the glass? Link to comment Share on other sites More sharing options...
IC Posted September 1, 2004 Share Posted September 1, 2004 Depth Of Field. Where the main part of the object being viewed is in focus and the rest is blurred. Just like photography but much harder to get good results. Link to comment Share on other sites More sharing options...
trhoads Posted September 1, 2004 Share Posted September 1, 2004 The images look good. Is it intentional to have the walls and roof the same material. Also looks like the stairs might be hard to build, they seem a little thin. I actually like the glass, maybe just a small amount of relfection, but it does not seem like there is much to reflect with a white background. OVerall, I like them. IC, is it possible to adjust the DOF in VIZ? I will have to look into that. Could be fun to try. Link to comment Share on other sites More sharing options...
Buffalo Bills Posted September 1, 2004 Share Posted September 1, 2004 Travis, Yes you can use DOF in Viz. If you click on your camera and then go to the modify panel you will see the settings for DOF. I haven't tried it either, But if you could master it I'm sure it would look good. Link to comment Share on other sites More sharing options...
gustav_gans Posted September 1, 2004 Author Share Posted September 1, 2004 @trhoads yes it is intentional to have all walls (outside and inside at the stairs) in the same material - looks really good in reality Link to comment Share on other sites More sharing options...
