Christiaan Posted November 17, 2011 Share Posted November 17, 2011 Hi All, I'm Christiaan and I am a Engineer/disigner bij a large Civil Engineering firm. I have an question about mr Sky Portal, when ik place that it give me verry strange Reflections see image. Can someone help me furter? Thanks in advance. Christiaan [ATTACH=CONFIG]45776[/ATTACH] Link to comment Share on other sites More sharing options...
marius e Posted November 17, 2011 Share Posted November 17, 2011 Uhm, I suggest you show us where the sky portal is in relation. BUt my guess is that its no reflection just low quality samples, you need to bump that up in order for those specles to disappear. Link to comment Share on other sites More sharing options...
Christiaan Posted November 17, 2011 Author Share Posted November 17, 2011 Marius, Thanks, Thee Mr Sky portal is comming from behind. When I don't use the sky portal there is no noise en less daylight. Do you mean to bump up Image precission? CP Link to comment Share on other sites More sharing options...
marius e Posted November 17, 2011 Share Posted November 17, 2011 Sky portal settings: adjust the shadow samples to more sampling. Link to comment Share on other sites More sharing options...
Christiaan Posted November 17, 2011 Author Share Posted November 17, 2011 That's a lot better, but the noise is even there. CP [ATTACH=CONFIG]45778[/ATTACH] Link to comment Share on other sites More sharing options...
marius e Posted November 17, 2011 Share Posted November 17, 2011 post some of your rendering settings up, lets have a look! Link to comment Share on other sites More sharing options...
Christiaan Posted November 17, 2011 Author Share Posted November 17, 2011 Thanks for the help! These are the settings I use. [ATTACH=CONFIG]45782[/ATTACH][ATTACH=CONFIG]45781[/ATTACH][ATTACH=CONFIG]45780[/ATTACH][ATTACH=CONFIG]45779[/ATTACH] Link to comment Share on other sites More sharing options...
marius e Posted November 17, 2011 Share Posted November 17, 2011 [ATTACH=CONFIG]45783[/ATTACH]See Attached image. You wont have all those setting I have, non the less adjust as per images. Also, disable GI, only try use Final Gather. Are u using any other lights? Link to comment Share on other sites More sharing options...
Christiaan Posted November 17, 2011 Author Share Posted November 17, 2011 Oops it's getting worse.... I use only one Sky light and a mr Sky Portal to put the light in the room. PS great website you heave, realy nice images! [ATTACH=CONFIG]45792[/ATTACH] Link to comment Share on other sites More sharing options...
Justin Hunt Posted November 18, 2011 Share Posted November 18, 2011 Try blurring the horizon of the mrsky, other than that when using photons, leave the FG bounces to 0 (they are discarded anyway). With the photons I find it better to use more photons to get detail, rather than having a high photons per sample setting. A bit of a shameless plug but check out my lighting tutorial for a better explanation http://justinhuntvisualization.blogspot.com/ jhv Link to comment Share on other sites More sharing options...
marius e Posted November 18, 2011 Share Posted November 18, 2011 mmm, What glass material are you using, that might cause that grainy effect, since all the other settings are fine. Post an image of your material settings for us. Link to comment Share on other sites More sharing options...
Christiaan Posted November 18, 2011 Author Share Posted November 18, 2011 Guys, thanks a lot! problem solved with specs from justin. [ATTACH=CONFIG]45805[/ATTACH] Link to comment Share on other sites More sharing options...
