zewanil Posted November 18, 2011 Share Posted November 18, 2011 Hello people i am trying to achieve a material with no success.... I would like to add to type of bum for the same object .... The thing is that i would to uvw mapping each of the two different material so i can really have the look that i want .. the first image that i post is the material that i would like to achieve ... There is the wood and the grain ... and there is also another bump with is like it hasn be sanded if you know what i mean . So i post the wood material and is bump material and also the not sanded bump ... ( i know its not drawend correctly but i will fixed well i will find out how to do it ) So how do i do this ? Do i have to play with the channel ? thanks so much for your time P.[ATTACH=CONFIG]45796[/ATTACH][ATTACH=CONFIG]45798[/ATTACH][ATTACH=CONFIG]45799[/ATTACH][ATTACH=CONFIG]45797[/ATTACH] Link to comment Share on other sites More sharing options...
Bruce Hart Posted November 18, 2011 Share Posted November 18, 2011 (edited) Yes you will need a composite map or mix map in the bump slot with different mapping channels for each bitmap used . Then apply two UVW map modifiers to the same object with map channels on each that correspond to your bitmaps. Edited November 18, 2011 by Bruce Hart Link to comment Share on other sites More sharing options...
beestee Posted November 18, 2011 Share Posted November 18, 2011 In this case I think you would need a specular/reflection map to represent the sawcut pattern you are trying to achieve moreso than additional bump. I am sure there is a little bump in it as well, but it seems more scuff than bump to my eyes. Perhaps even multiplying the diffuse with the sawcut pattern a little might be necessary. You will still need to utilize mapping channels and multiple UVW maps to do this. Combine all of it and I am sure you can achieve a convincing replication of that material. Link to comment Share on other sites More sharing options...
zewanil Posted November 21, 2011 Author Share Posted November 21, 2011 thanks guys .. i am wondering why i can not find the composite material of vray ??? Link to comment Share on other sites More sharing options...
Bruce Hart Posted November 22, 2011 Share Posted November 22, 2011 VrayCompTex in the map slot is one option Link to comment Share on other sites More sharing options...
zewanil Posted November 22, 2011 Author Share Posted November 22, 2011 yes vraycomptex seems to not be there ... have it happen to anyone ? thanks Link to comment Share on other sites More sharing options...
