Stereoscopic images
Arnold Sher
Hi everyone,
My question is directed to the guys that have used vray 2.0 stereoscopic image generator and did you guys managed to get to work. The rendering out is pretty straight forward, one gets a left image and the right image in a single render, then we put into stereophoto maker software to generate the image which we generate. The trouble is that we can see the cyan and magenta edges and we have the 3d glasses that we get from cinema and we have fancy ones that comes with Samsung 3d TV but we cannot for the live of it get the image to become "3d". Can anyone point us to the right direction as the more we've read about it the more confused we got. Thanks guys...
Sounds like you're mixing 3d technologies. There are several different ways to display 3d images you can't use the glasses from one technology to view another.
sounds like your are producing a cyan/magenta image. You'll need to use Cyan/Magenta glasses to view it.
The glasses you get in the cinema are polarized so you'd need a polarized monitor to view them. The Samsung glasses are probably active shutter...and probably incompatible with pc. They do make active shutter systems for the pc however. For these two types of systems (polarized/active shutter) you'd need to produce the image differently and use playback software that supports stereoscopic playback.
Easiest (but not the best) way would be to just get yourself cyan/magenta glasses.
