lost xyz axis
nodar1978
hi guys. i lost xyz axis and it is difficult, rotate or scale objects.
''X'' doesn't works, i tried in preferences to switch on and off ''show gizmos'' doesn't help.
trying to find .ini file with name 3dsmax.ini but cant find.
Please give me some tips, project just stopped because of that, i mean it goes very slowly. need your help
thank you in advance
the max.ini is located at C:\Documents and Settings\username/\Local Settings\Application Data\Autodesk\3dsmax - 32bit\enu it's an open with document. If you cannot find this then you need to click on tools folder options, views under hidden files and folders put the dot in there and then click apply and then ok this will show all the hidden files and folders. Make sure you restart your computer autodesk will replace it
Edited by datacrasher
