anvaraziz Posted September 2, 2004 Share Posted September 2, 2004 hai.. chek it out..... render with default scanline... little PS tweaking.... Link to comment Share on other sites More sharing options...
kippu Posted September 2, 2004 Share Posted September 2, 2004 not bad for a scanline Link to comment Share on other sites More sharing options...
Jason Matthews Posted September 2, 2004 Share Posted September 2, 2004 What are your settings? Are you using Radiosity? I think the scene is too bright, and not enough contrast. I like the modeling though. Make sure your AA is checked in the render options because everyhtng looks jagged. Maybe try a camera correction modifier to straighten uo the shot some. The shadow under the table is producing very intense indirect bumping. If you are using radiosity, change the material into an advanced lighting material and reduce the indirect bump mapping. I would also change the wall material into an advanced lighting override material and reduce the reflectance scale down to like or so. There is a whole list of reflectance values for materials some where, maybe in the help menu that you should go by. _Jason Link to comment Share on other sites More sharing options...
anvaraziz Posted September 2, 2004 Author Share Posted September 2, 2004 ya the shadow under the chairs... ill do it,,, dont used radiosity....only standerd lighting ,,,,couse this one need to be completed on a hury,, no time to calculate indirect ilumination n all,,, so ....one n half hour work, render on 1500 X 1000 in 1.3 min... those plants n flowers r all done in max using opacity mapping...only done some color correction in PS Link to comment Share on other sites More sharing options...
kicks Posted September 2, 2004 Share Posted September 2, 2004 Link to comment Share on other sites More sharing options...
jysngltndz Posted September 2, 2004 Share Posted September 2, 2004 the image is good but its over exposed.. another thing is the wood floor its too shiny for me, the sofa set i think would be better in dark color so it could create contrast on your image.. an addition of background will also be good.. Link to comment Share on other sites More sharing options...
jysngltndz Posted September 2, 2004 Share Posted September 2, 2004 kicks(daghan salamat!!!!) thank you... caravan again.... anvar: excuse the insertion of diff topic... Link to comment Share on other sites More sharing options...
marckie258 Posted September 2, 2004 Share Posted September 2, 2004 your image is over-exposed. need to lower the contrast a little bit. belated jayson... mark MAC Studio Link to comment Share on other sites More sharing options...
renato Posted September 2, 2004 Share Posted September 2, 2004 agree. You need to reduce the gamma. Besides that, it looks very nice to me. Link to comment Share on other sites More sharing options...
anvaraziz Posted September 4, 2004 Author Share Posted September 4, 2004 thanks for all the comments.... Link to comment Share on other sites More sharing options...
