Jeff Mottle Posted September 2, 2004 Share Posted September 2, 2004 Hey guys, What video driver are you using? I have a geForce 4400 Ti and when I rebuilt my system last week, installed the latest 61.77 Nvidia Driver. The problem is that I'm loosing my icons in max and getting odd artifacting. Also I typically run SZB as I find OGL to be too unstable. Link to comment Share on other sites More sharing options...
Jeff Mottle Posted September 2, 2004 Author Share Posted September 2, 2004 Hmm, not sure if this is a driver issue now. I seem to loose icons randomly when I switch from the default UI to the Discreet Dark (which I prefer). Odd. Never had this issue before Link to comment Share on other sites More sharing options...
trhoads Posted September 2, 2004 Share Posted September 2, 2004 Jeff, how do you switch to the Dark UI, I have seen others with screen shots like that, I can not see, to locate where to changes that. I kina like the darker setup. Link to comment Share on other sites More sharing options...
David Knourek Posted September 2, 2004 Share Posted September 2, 2004 Thats strange Jeff. Im running a GF 4 Ti4600 and a GF FX5900 Ultra both running the latest drivers and no problems with discreet dark gui. -dave Link to comment Share on other sites More sharing options...
radioVOY Posted September 3, 2004 Share Posted September 3, 2004 if you formated your HD and reinstall all the software back check for the updates on windows and some software that need update too. i have a gforce TI 4800 cracked to a quadro 4 980xgl and when i formated my drive windows screw all my monitor config. make an update without the service pack 1 and everything works fine. hope this helps. Link to comment Share on other sites More sharing options...
JM Ataide Posted September 3, 2004 Share Posted September 3, 2004 Hi Jeff. I'm running a Quadro 750 XGL, nVidia drivers v.61.40 and MAXtreme v.6.00.07. 3ds max 6.0. OS is Windows XP professional with latest updates. I tested dark UI without problems. Which driver are you using in 3ds max (open gl, directx, MAXtreme...)? Travis, to switch to the dark UI: Customize -> Customize user interface -> Colors -> Load Link to comment Share on other sites More sharing options...
pipjor Posted September 3, 2004 Share Posted September 3, 2004 Travis, Customize/Load Custom UI Scheme/discreet-dark.ui Link to comment Share on other sites More sharing options...
trhoads Posted September 3, 2004 Share Posted September 3, 2004 pipjor, thanks, i guess that one is not available for my release of VIZ. thanks for your help anyway. Link to comment Share on other sites More sharing options...
Jeff Mottle Posted September 3, 2004 Author Share Posted September 3, 2004 Hi Jeff. I'm running a Quadro 750 XGL, nVidia drivers v.61.40 and MAXtreme v.6.00.07. 3ds max 6.0. OS is Windows XP professional with latest updates. I tested dark UI without problems. Which driver are you using in 3ds max (open gl, directx, MAXtreme...)? Travis, to switch to the dark UI: Customize -> Customize user interface -> Colors -> Load It doesn't matter what graphics mode I'm in (I tested OGL and SZB), in both I loose all the icons from the floating menus and all of the buttons below the sample boxes in the material editor. Very weird. Link to comment Share on other sites More sharing options...
Jape Posted September 4, 2004 Share Posted September 4, 2004 Think you'll find the problem is probably youre detonator drivers, dont know if you lose youre icons also in other programs/windows itself, but had a friend that loosed icons on his startbar, IE, outlook etc. Try other detonar drivers, preferably WHQL ones, arent the fastest but are the most stable ones, also make sure you're old drivers are completely gone by using detonator destroyer, it removes all info/data from last driver wich often causes problems. If you have dualhead card/setup check the settings for them (different rfrsh rates, first one 32bit second 16bit for example causes problems with icons) Alternativly, if you can, switch it for a good working vid card to check if its youre hardware (vid card memory???) that malfunctions, Though if you only experience this thing in max, it could very well be max thats causing te problem (restart after crash??, corrupted files maybe??) Link to comment Share on other sites More sharing options...
Jape Posted September 4, 2004 Share Posted September 4, 2004 one more thing, install the newest directx 9.0c , 60 and up versions supports 9.0c Link to comment Share on other sites More sharing options...
