frog_a_lot Posted December 2, 2011 Share Posted December 2, 2011 Ok sso i haven't done loads of animations in vray, mainly stills. But when we do animation we precalc the Irrandiance Map and light cache. We have always precalced light cache for the full frames. If the Light cache is set to say 2000 and 'world' and 'fly through' does this mean i should only be rendering one single frame and that will calc for the whole animation? And then calc Irr Map every 5th or 10th for whole frame range. Im talking simple walk/fly though with no moving objects just moving camera. Cheers Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted December 2, 2011 Share Posted December 2, 2011 yes you are correct, now do not forget to select "camera path" in LC. Link to comment Share on other sites More sharing options...
subburb Posted December 12, 2011 Share Posted December 12, 2011 yes, 1 LC render in flythrough mode, wich should be blurry as it contains all frames in one go. Then an irrmap every 5-10 frames, depends of the speed of your camera. About "use camera path" : i'va made several tests, and finally always check it OFF !! This feature is usefull ONLY for a little anim and if your camera moves a little bit. In all other cases (real flythrough), you may UNCHECK it ! Link to comment Share on other sites More sharing options...
