Help modeling this arc
valeriomanfredi
[ATTACH=CONFIG]46026[/ATTACH]
Hi all, i need help with modelling this arc.
I've created a circle, converted to spline and leaved only the semicircle, then extruded. Now the problematic part: i need to make the three internal chamfers; i've tryed with shape merge, lofting and conform, but with the same poor result in the upper circular part, polygons crossing and a resulting bad model.
Can someone help me.
Thanks.
Easy way to do it is like this:
You need two splines. One is the "rail" the leading profile, the half-circle spline you already have.
Second you need the "cross-profile" with all the small details,chamfers,etc. Then you need to use modifier "sweep", apply it on the "rail" and select custom profile you created "cross-section".
Here is a gothic window I made using this technique:
I made some screenshots, hope it can help you something.
1. Make a shape, extrude with segments = 60 (or higher if you want the a smooth curve).
2. Convert to poly, select edge, connect with 2 segments.
3. Creat a circle, move to object 1's center.
4. Select object 1, go to geometry -> compound objects -> ShapeMerge, pick the circle.
7. Select faces, extrude and insert. maybe it has this problem
8. Use "target weld" to fix it, extrude and insert again :).
9. Creat a big circle, convert to spline, remove a half. Cap the first hole on object 1, add symmetry, pathdeform, pick the big arc.
You can download my max file here: http://www.mediafire.com/?y7d61c8w31883ik
Regards
Edited by Hoa Dinh
