Viewport Problem...take a peek
danb4026
I can't see what version of max you're using, your image is to small, i'm assuming 12.
But I've been having the same problem since upgrading to max 12. I did all the software updates, but it still happen on occasion. I thought i maybe ram related, so i upgrade from 8g to 16g, but still happen.
Sometimes if I minimalize then maximise Max it fixes the issue.
What windows version are you running? There is a bug with windows7 and multiple monitors, where if you turn you monitors off and on again all the dialogue windows move the the monitor that was first turned on and would often kill the max viewport shading.
jhv
Nothing worked. I had to shut down Max and reopen. Now its back to ok....it will happen again I am sure of that.
I am running Win 7 64, with multiple monitors. The monitors do shut themselves off after about 30 minutes and my mouse click brings them back to life. But the dialogues don't move, just the viewport poops.
I have the latest driver for my card. I also installed SP2 a couple of weeks ago for Max Design 2012. It said it installed fine, but when I look up version info under Max's help menu it doesn't say SP2.....it says Release 14.0 SP1. Not sure what that means or if the installation of SP2 really took.
