jzon Posted December 13, 2011 Share Posted December 13, 2011 Hi, can anyone help me, how to make the normal pivot appear? for example, if we finished create a box, there should be x,y,z pivot at the box object, isn't it? mine was disappear for the last 2 days, it is like doing 3d in expert mode, do anyone have any idea? Link to comment Share on other sites More sharing options...
Professor Posted December 13, 2011 Share Posted December 13, 2011 Did you try pressing "X"? That toggles the gizmo on and off. Also, sometimes I forget to put an object back to top level. If you're in a sub-object mode sometimes you won't see the pivot icon. Not sure what else it could be, hope that helps. Link to comment Share on other sites More sharing options...
Mario De Achadinha Posted December 13, 2011 Share Posted December 13, 2011 Its generally "x" that makes it disappear. You could have also made it smaller by pressing "-" a few times.... try + to make it larger? Link to comment Share on other sites More sharing options...
jzon Posted December 13, 2011 Author Share Posted December 13, 2011 I've try that one, i try also the preferences settings and turn on the gizmo boxes, but it didn't work out, finally, my friend told me to go to views-click on the shows transform gizmo, then the problem solve. I think maybe i eventually hit that command while trying to use command~show material in viewport as-, anyway, thanks guys! Link to comment Share on other sites More sharing options...
