axie Posted September 4, 2004 Share Posted September 4, 2004 I've had enough of banging my head against the wall, can someone please tell me or point me to a place where I can find out how to make doors open and close during a fly-through? I just can't seam to get the things to move. Many thanks, Link to comment Share on other sites More sharing options...
anvaraziz Posted September 4, 2004 Share Posted September 4, 2004 its simple yar.... first group the door u need to animate,,, then move the pivot to one end of door where the door is fixed to the wall...then set keys on frames u need to open n close the door... for setting key,,, if u need the door to be opend from frame 50.. first set a key on first frame with the door closed , move the time slider to frame 50 set another key.(with door closed), move slider to 60 ..rotate the door n make it open ..set another key ,,,after camera passed through the door if u need the door to close back , move time slider to 70 , close door, using rotate... set key.. u can play with the keys to control the speed of opening n closing ,,,,, increase the frames between two keys ll increase the time taken to do the action,,,,u can use max help file to know more bout setting keys... Link to comment Share on other sites More sharing options...
axie Posted September 4, 2004 Author Share Posted September 4, 2004 Was that for Max or Archicad anvaraziz? Link to comment Share on other sites More sharing options...
anvaraziz Posted September 4, 2004 Share Posted September 4, 2004 for max.... Link to comment Share on other sites More sharing options...
Ace_Face Posted September 4, 2004 Share Posted September 4, 2004 axie said: Was that for Max or Archicad anvaraziz? Archicad doesn't support object animation. For that you will need to move to another render app. Link to comment Share on other sites More sharing options...
axie Posted September 6, 2004 Author Share Posted September 6, 2004 Really? Hmm, I was pretty sure i've seen animated objects like a fountain in a archicad flythrough, maybe I need to lay off the drugs. Anyways, thanks guys. Link to comment Share on other sites More sharing options...
CU mirco Posted December 20, 2004 Share Posted December 20, 2004 Quote Archicad doesn't support object animation No? I don't think so! ArchiCAD can move the object ! Use the gdl! Quote i've seen animated objects like a fountain in a archicad It's a frank's (chin) object. CU mirco Link to comment Share on other sites More sharing options...
CU mirco Posted December 22, 2004 Share Posted December 22, 2004 See this example made in ArchiCAD: (Omuncolo's walking) CU mirco http://www.3dsmile.it Link to comment Share on other sites More sharing options...
spankissimo Posted February 20, 2005 Share Posted February 20, 2005 the pnly way i found this was decently doable was by making 2 different movies and mixing them in virtualdub (free - premiere wanabee). You make 1 movie till you get at the door , and then you start your next movie with the door open, you can make some single renders to add some smoothness to the opening door action. It's a stupid way but it's the only 1 i can think of that dosen't involve any other expensive app. Link to comment Share on other sites More sharing options...
