clivengu Posted December 19, 2011 Share Posted December 19, 2011 Is there a way I can set Vray to render from Top to bottom (left to right and slowly going down), instead of the standard vray rendering from 10 O' Clock ... and rotating 360 degress anti clock wise? I have tried to check for such setting but no such luck.. The reason I will like to do that is because sometime I need to stop my rendering halfway, and resume the rendering from where it stops (mayb first top.. then later bottom.. and i can combine the rendering later on in photoshop). The current rotating rendering sequence doesnt allow me to region render part by part.. as it always render at an angle. So most area have to Re- render again. Sorry if it is difficult to get my explanation Anyone getting this? Thanks Link to comment Share on other sites More sharing options...
Bruce Hart Posted December 19, 2011 Share Posted December 19, 2011 Settings Tab - System Rollout -Render region division. Change "triangulation" to Top->Bottom. You can also use the Track mouse while rendering button in the VFB as well as render region. Link to comment Share on other sites More sharing options...
clivengu Posted December 19, 2011 Author Share Posted December 19, 2011 OHh!! Thanks a million! I should have found out this long ago... rather than rerender most of the views... this is great! Link to comment Share on other sites More sharing options...
neil poppleton Posted December 19, 2011 Share Posted December 19, 2011 Also look at region rendering.. Link to comment Share on other sites More sharing options...
frog_a_lot Posted December 21, 2011 Share Posted December 21, 2011 Can do Top->Bottom, Bottom->top, Left->Right, Right->left etc all from that same box Link to comment Share on other sites More sharing options...
