pwolf21 Posted December 22, 2011 Share Posted December 22, 2011 I'm looking for advice of how I can create a wet looking top coat on a wood top. I will need to be able to adjust the wetness look depending on the shinn. I hope this makes sense to you... Link to comment Share on other sites More sharing options...
Ismael Posted December 22, 2011 Share Posted December 22, 2011 Perhaps you can get ideas here: http://www.neilblevins.com/cg_education/wet_materials/wet_materials.htm Link to comment Share on other sites More sharing options...
Dave Buckley Posted December 23, 2011 Share Posted December 23, 2011 Which render engine and software are you using? Link to comment Share on other sites More sharing options...
pwolf21 Posted January 3, 2012 Author Share Posted January 3, 2012 Which render engine and software are you using? I'm using 3DS max 12 with V-Ray 2.0 Link to comment Share on other sites More sharing options...
Dave Buckley Posted January 3, 2012 Share Posted January 3, 2012 Well in that case I'd use a vray blend maybe? Base material is your wood, coat material is your wetness, controlled with a mask? Link to comment Share on other sites More sharing options...
pwolf21 Posted January 3, 2012 Author Share Posted January 3, 2012 Well in that case I'd use a vray blend maybe? Base material is your wood, coat material is your wetness, controlled with a mask? what do you mean when you say controled by a mask? I've never used a mask before. Link to comment Share on other sites More sharing options...
LordRaven Posted January 3, 2012 Share Posted January 3, 2012 This may help you although it is not exactly what you were looking for. The workflow is somewhat similar. http://www.cgdigest.com/vray-wet-materials/ Link to comment Share on other sites More sharing options...
