VRay 2.0 and Vue xStream 9.5
Ardak
Hi, I have this question with the combination of those two. Has anyone else came to a rendering-time problem? I had simple scene with ground covered with foliage, some background trees and three shacks modeled with 3DS MAX. The frame-time for one HD-frame (1280x720) was 4 hours, which is insanely long. Really cripples the capability of doing any sort of animation. The renderer settings were pretty simple, VRay Frame Buffer was enabled, Adaptive DMC Sampler in use with 1/8 settings, Irradiance Map with Medium preset and Light Cache with 2000 subdivs, the regular sample size and with World and Fixed settings. Here's a picture of the render. It was initial test render so there are missing textures, and sorry about the overly green grading, I adjusted it with a display where colors were messed up so it turned out to be a bit wrong. I have heard that displacement may cripple the rendering times when using Vue elements, so I started a new render without the shacks.
