white dots noise on reflective n transparent object
fudiiduf
hi all.. im new in this fry forum..i just started to use fryrender for my production, actually im quite happy with performance n result, but some problem make me desperate to trick it..this my most problem when i work with the transparent or reflective material like water or metal..theres always appear the dots n white spots like noise..n that cant be fixed even take the render time longer...thanks for all ur advice and helps.. :(:confused: thank you very much, best regards n happy new year..:cool:
  • 2 weeks later...
Here is a link to a pdf tutorial on how to create pool water caustics:
Btw, someone try Arion 1.6? I have are problem with waterpool caustic. One-plane surface with standart 1,33 water and noise geometry. Fryrender make ph.correct result? but Arion 1,6 DEMO don't cast anything. And I can't understand - this DEMO version problem , or the total injury.
