ActiveShade is not showing the right window.???
3dvizual
Hi.
I can't seem to get my vray RT to work properly.
I can't get vray to open a separate window for the active shade, and I can't get vray to render a selected window.
My 3ds max crashes often when i try to turn on the active shade. Anyone else has these problems.?
Vray is an active shade render. Text from the vray manual (Open the Render Setup dialog and choose V-Ray interactive renderer as the current ActiveShade renderer. )
But my active shade will not turn on. I have assigned the VRAY RT 2.20.01 as the current active shade render.
When I see the log, I can see that vray is loading the images and so on, but no window pops up.
For a couple of days ago it worked for a half an hour or so, when i selected a new viewport the active shade window rendered the selected window.
I have no clue what I am doing wrong. My computer makes noise like it is working hard.
mmmm ok i was wrong as usual vray has its own active shade :( the one in max only uses the p.view that why i always have the p.view locked down so it cannot render from another view.
what kind of noses are you getting from your computer is it a ticking sound like a clock? if so then your hard drive is on it's way out you'll need to buy another one......
mmm i am not sure, maybe you don't have enough ram, as your scene gets bigger and max will use a lot more ram some-times your computer will slow down so i would not use active shade. because your pc is working too hard. as active shade updates you're scene automatically without you needing to render.
  • 3 weeks later...
  • 8 months later...
