chow choppe Posted January 6, 2012 Share Posted January 6, 2012 Hi everyone. i want to ask a question from AE users doing architectural animations. lately i have seen some animations in which 2 - 3 shots are just panned images or zoomed in or zoomed out images which create a sense of animated when viewed with actual animations in the same video. so its like using 4- 5 seconds after real animation shots. it kind of looks cool and also saves time. i want to ask how its done and i am concerned about what size still image should be rendered at. if my final composition is full HD i.e 1,920 X 1080 what should i render my still image at so that i am able to pan enough and similarly zoom out i hope i am clear for eg see first 33 seconds of this walkhrough. this is what i am talking about. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted January 6, 2012 Share Posted January 6, 2012 If you are going to zoom in on a still you definitely need to go larger with your render, but I don't think you need to go crazy with it. When I have done this I usually output a 1280 and render a 1920. for you maybe go 2560 or something so that your qualilty will stay the same. Another cool trick, if the nature of the image allows, is to put a slight wiggle on it like its a hand held camera. On slow moving shots its gives a cool feel. As to the how its done... you can just animate a scaling of the image and the wiggle is a plugin and/or a position animation. Pretty simple. Link to comment Share on other sites More sharing options...
chow choppe Posted January 7, 2012 Author Share Posted January 7, 2012 thanks for the tips. will try it thanks Link to comment Share on other sites More sharing options...
chow choppe Posted March 29, 2012 Author Share Posted March 29, 2012 i am trying to pan a still image from left to right . but its coming out jerky from after effects in final output. i am using Dv PAl widescreen output size and 30fps. added a little blur to it also Link to comment Share on other sites More sharing options...
John Dollus Posted March 29, 2012 Share Posted March 29, 2012 are you certain it isn't just your system lacking the ability to playback the compiled format smoothly? Link to comment Share on other sites More sharing options...
Fooch Posted March 31, 2012 Share Posted March 31, 2012 3dsmaxed said: i am trying to pan a still image from left to right . but its coming out jerky from after effects in final output. i am using Dv PAl widescreen output size and 30fps. added a little blur to it also codec--> export to h264 mov. plus add motionblur in AE , not just a regular blur Link to comment Share on other sites More sharing options...
chow choppe Posted March 31, 2012 Author Share Posted March 31, 2012 @john: no its not about the system lacking power as other things are playing fine in the same composition. when i change the fps to 60 in composition settings the motion is very smooth but that will disturb the whole frame rate of compositiond and speed the animation . @Fooch u mean adding a motion blur to the whole image/layer? Link to comment Share on other sites More sharing options...
Fooch Posted April 1, 2012 Share Posted April 1, 2012 --> layer. There is a motionblur button. Use F1 for help. Plus it sounds like your frame rate isnt keeping up on playback too. There might be dropframes Test that by stepping through the frames. What codec / res are you outputting too. Link to comment Share on other sites More sharing options...
