shYUel Posted January 7, 2012 Share Posted January 7, 2012 (edited) Studio/Institution: My ownGenre: OtherSoftware: 3DsMAX, VRay, PhotoshopDescription: Hello, so this is my WIP and I should finish it by the end of this month if you help me by C&C it.. It should be like DJ STUDIO, simple and clean.. Thanks. Edited January 10, 2012 by shYUel Link to comment Share on other sites More sharing options...
datacrasher Posted January 9, 2012 Share Posted January 9, 2012 Ilija IMO the lighting is a bit bright, add some refection to the floor. also the lighting is a bit low a person walking through there would hit his/her head on the lights Tony Link to comment Share on other sites More sharing options...
Janwalli Posted January 9, 2012 Share Posted January 9, 2012 brightness of outdoor does not fit to the light indoors. With light shining that bright on the floor, the outside should be pretty washed out I think. Also the scene has a Alice in wonderland feeling, at least I have difficulty to find the correct scale. Link to comment Share on other sites More sharing options...
shYUel Posted January 10, 2012 Author Share Posted January 10, 2012 Thank you guys very much for help.. I really appreciate it! Well, lightning in PS edited.. It was very hard to work in PS for the first time, so I tested some colors... Here's the second result: http://www.dodaj.rs/f/3f/OE/3Fe9c28m/studio2.jpg Thanks. Link to comment Share on other sites More sharing options...
datacrasher Posted January 10, 2012 Share Posted January 10, 2012 The lighting is too bright you need to lower it and add a yellow tint to make the room feel warmer if you look at a real light it's not white it's yellowish. put some shelves on the wall so you can add some cd cases. Link to comment Share on other sites More sharing options...
shYUel Posted January 19, 2012 Author Share Posted January 19, 2012 Actually this is NOT DJ Studio room, but ok.. It's a test of lightning and shadows... Here's another TEST: If you can write down about what parts I should make more darker, or warmer? You could use PS to show me too, thanks. Link to comment Share on other sites More sharing options...
Ivaylo Kondzhagyulov Posted January 22, 2012 Share Posted January 22, 2012 For a better result and realism for the lightning i think, you have to use "vray sun" + "vray sky" for the main light sourse and to put outside the window "vray light plane" with chek "sky portal". Try with this settings - Image sampler: "Adaptive DMS"; Anti Aliasing filter -"Blackman"; Color Mapping - "Reinhard" with "burn value" among 0,4-0,7; "Vray frame buffer" and "Vray Camera". Link to comment Share on other sites More sharing options...
