WIP Dining room with garden view
voltaire_ira
this is an update to my previous post of a residential project i'm currently designing. Finally added some details but still far from complete.any comments to improve will be highly appreciated!thanks!
images were rendered using mentalray for max6 with low settings to increase workflow.final images will be rendered using high settings(if i get the tweaking right!hehehe)
nice renderings voltaire....
1st image- i like your water( is it bump with map or ripple?)
2nd image- great chrome... floor is too shiny ithink, and i notice some checkered material on top of the image are those overlapping materials or part of your design?.. nice mood!
nevertheless i like it!!!! :D
-thanks everybody. the water was made using a plane with an ocean lume), submerge(lume) and water surface(lume) in the displacement, volume and surface material respectively in a mentalray shader. tutorial can be found at lumetools.com.
-the chrome material made use of metal(lume).
-actually there are overlapping objects on top of the curtain..forgot to delete one object so the materials overlapped.
-yup, floor looks too wet and maybe curtains need adjustments. the environment is a hdri map..but i will be adding more bitmap trees on the background.
