Savior Posted January 10, 2012 Share Posted January 10, 2012 Studio/Institution: perosonal workGenre: OtherSoftware: Maya, Mudbox,AdobieWebsite: http://www.lavis.seDescription: Hello guys I have a hugh problem getting my foliage correct... it dose not look real. It is worst on the transition from CG to photo in the BG. help needed Link to comment Share on other sites More sharing options...
dgn-freedom- Posted January 10, 2012 Share Posted January 10, 2012 My "newbie" advices: - Try to add more green colour and contrast to background photo. It will fit the foreground - Play with LIGHTing and shadows. Maybe different position of light source should be nice - For the background try to add some FOG starting behind the playground and folowing the background photo I hope its gonna help Link to comment Share on other sites More sharing options...
Savior Posted January 10, 2012 Author Share Posted January 10, 2012 thanks for your input mate. Fog will probably solve the issue with a bad transition. The problem is I want to have a late afternoon, and there is no fog on a sunny afternoon=(. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted January 10, 2012 Share Posted January 10, 2012 All you need to do is match your green colors. Take the maps that you are using for your grass and trees and colorize them in PS either by a Hue/Saturation Adjustment Layer or put your image behind the map layer in PS and go Image>Adjustment>Match Color and asource the image layer. The only other need would be to harden your shadows. It looks like the sky color you are using is brighter that the image, or something like that, but this fix really depends on your sun/sky/environment setup. I think this will go a long ways towards getting your CG and Backplate to match. Good Luck! Link to comment Share on other sites More sharing options...
Savior Posted January 11, 2012 Author Share Posted January 11, 2012 I failed to match the colors in the original BG so I change to an image who looked more right from the start. Then I used the match color and added some people. Link to comment Share on other sites More sharing options...
dgn-freedom- Posted January 11, 2012 Share Posted January 11, 2012 Hey, it looks pretty beatiful! maybe the grass in foreground is little bit high according to the standing woman but after all it looks good! Link to comment Share on other sites More sharing options...
Leonard15 Posted January 30, 2012 Share Posted January 30, 2012 Looks pretty good. Have you considered using Vue as a plugin? Link to comment Share on other sites More sharing options...
