bharris Posted January 11, 2012 Share Posted January 11, 2012 I'm trying to find a way to easily panelize a wall. Somewhat similar to picture below. I've looked at the Floor Generator script from cg-source.com. Seems to work well on floors (horizontal surfaces) but not vertical surfaces unless i'm doing something wrong. I usually model in Revit so the walls are already in position, they just need to be "panelized". Any quick methods? [ATTACH=CONFIG]46636[/ATTACH] Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted January 11, 2012 Share Posted January 11, 2012 Use the sub object mode of an edit poly to select edges and connect them. If you don't hit the button for connect and instead hit the menu next to the button you can control the number of connections and if they are even or skew to the middle, edge, etc... After you establish your lines on the surface grab all faces you want to make a panel from and inset by a gap/grout distance. without deselcting, hit ctrl+i to invert and then extrude by local normal and you should be able to keep your wall thickness the same and carve gaps into the wall for panels. If you additionally change the material ID's to a different number then your "grout" can be one color and the panels another by using a myulti-sub material. I hope this is clear. It should be an easy process. Good luck! Link to comment Share on other sites More sharing options...
bharris Posted January 11, 2012 Author Share Posted January 11, 2012 Corey, Thanks for info. I know of this method, yes it is quite easy in principle, but time consuming compared to the floor generator script when you are doing large facades. I guess I'm looking for a script, or better yet the floor generator script being used on vertical surfaces. Has anyone used the FG script on vertical shapes? Link to comment Share on other sites More sharing options...
Ismael Posted January 12, 2012 Share Posted January 12, 2012 Maybe useful http://www.itoosoft.com/railclone.php There is a 'Light' version. Link to comment Share on other sites More sharing options...
David Arbogast Posted January 12, 2012 Share Posted January 12, 2012 (edited) Brett, I think you can get floor generator to work for you if you: 1. In Edit Poly mode Detach (copy) the faces of a wall (you'll need to do this one wall at a time). 2. Rotate the detached/copied faces 90 degrees (parallel to ground plane). 3. Run Floor Generator to get your desired panelization solution. 4. Rotate the Floor Generator Panels into position. So, there are a few extra steps, but still might be a quick solution. Edited January 12, 2012 by David Arbogast Link to comment Share on other sites More sharing options...
s_tether Posted January 13, 2012 Share Posted January 13, 2012 I used the script below once to do the same thing, give it a go and see if it works for you: http://www.scriptspot.com/3ds-max/scripts/avizstudio-tools-atiles Link to comment Share on other sites More sharing options...
Ismael Posted January 13, 2012 Share Posted January 13, 2012 Nice script. Thanks Hull! Link to comment Share on other sites More sharing options...
