D C Posted January 27, 2012 Share Posted January 27, 2012 When I go to extrude an editable polygon the selected polygon automatically shoots up to 10m before I put the required height in the spinner. This means the block is preview extruded off the screen which I then edit to the required height. It is all slightly annoying. Is there anyway to reduce the initial polygon extrude preview to say 1m? Link to comment Share on other sites More sharing options...
datacrasher Posted January 27, 2012 Share Posted January 27, 2012 (edited) that is usual with max you can always left click to set the spinner to 0 and then put the amount you want If you're American then you can right click the spinner to set the spinner to 0 Edited January 27, 2012 by datacrasher Link to comment Share on other sites More sharing options...
