erkutacar Posted January 30, 2012 Share Posted January 30, 2012 I have 10 mr sky portals. Everything was fine till i changed environment shader from mr physical sky to a hdr map. Then switch it back to physical sky and realized sky portals r not visible. I can select them by name or via layers pallette, they r not hidden yet they r not visible either.. So each time i want to change a parameter i need to use one of 2 ways i mentioned.. Any ideas how to solve this frustrating situation?? Link to comment Share on other sites More sharing options...
Justin Hunt Posted January 30, 2012 Share Posted January 30, 2012 What display driver are you using? Sounds like a nitrous display problem Jhv Link to comment Share on other sites More sharing options...
erkutacar Posted January 30, 2012 Author Share Posted January 30, 2012 ahaha correct good diagnostic skills i use nitrous coz nvidia still haven't released quadro performance drivers for max 2012 and nitrous seemed faster than direct x.. so u think if i switch it to direct x and back to nitrous, it would solve the problem?? Justin Hunt said: What display driver are you using? Sounds like a nitrous display problem Jhv Link to comment Share on other sites More sharing options...
erkutacar Posted January 30, 2012 Author Share Posted January 30, 2012 hoollllyy shiitt now daylight sun node doesnt show i can only see its blue target line Link to comment Share on other sites More sharing options...
erkutacar Posted January 30, 2012 Author Share Posted January 30, 2012 issue resolved.. i tried installing new drivers for both my cards (q5000 and gtx580) and didnt work. by the way i first wanted to install gtx, i performed a clean install and for some reason it installed quadro drivers too anyways the issue was resolved by merging it into a new file.. Link to comment Share on other sites More sharing options...
