Eames Plywood Lounge
Studio/Institution: me
Genre: Residential Interior
Software: 3ds Max Design 2012 + Mental Ray
Description:
Here's a couple work-in-progress renders. I'm trying my hand at an Eames PW Lounge Chair-Walnut veneer. Obviously there's some mapping issues-the blue override that's over the edges...
Has anyone had success using Spline Mapping? For some reason I've got some whacky, over-sized extents, with no luck mapping the plywood veneer edges to curvilinear faces.
Later,
Matt
you can control your spline mapping in the tiling of the material. Once you get the Unwrap UVW on there and select faces, spline map, Pick spline, planar, fit, and hit apply, you can control the size of the map by tiling it more in your material editor.
The spline map usually starts out stretched and too big so I think will solve your problem.
Good Luck, you chair is looking good.
