trhoads Posted September 9, 2004 Share Posted September 9, 2004 I am using AutoCAD 2004, and have a problem with trimming lines. The screenshot attached shows the problem. I select a polyline as my line to trim to, and then click inside the small square to trim out the soild line that intersects my trim line. It leaves tails of the original line that extend beyond my trim line. WHY? I am a very experienced CAD person, and this is happening a lot with 2004. I never had this happen in r14. It does not matter if I select a line to trim to, or just select all to trim to, i get this a lot now, mostly when working on details. Anyone have any ideas on why it does this? Any help would be really appreciated. This makes it hard to join them all into one p-line, when all these little tails show up. Thanks for any help. Link to comment Share on other sites More sharing options...
IC Posted September 10, 2004 Share Posted September 10, 2004 Haven't experienced this one. What threw me for a while was the Shift Select default! Have you tried changing the TRIMMODE variable? Link to comment Share on other sites More sharing options...
trhoads Posted September 10, 2004 Author Share Posted September 10, 2004 TRIMMODE is set to 1, the other option, 0, will not trim chamfers and fillets the right way. Shift Select default, that one I am not familiar with. We just recently changed to 2004, so far so good, just a few bugs I am not pleased with. Link to comment Share on other sites More sharing options...
cadworx Posted September 10, 2004 Share Posted September 10, 2004 Did you check the edgemode variable? Try setting "edgemode" from 1 to 0 Hope this helps Link to comment Share on other sites More sharing options...
trhoads Posted September 10, 2004 Author Share Posted September 10, 2004 I think that is the solution, thank you very much. There is always something new to learn. Link to comment Share on other sites More sharing options...
CAD Posted September 11, 2004 Share Posted September 11, 2004 I second that... Link to comment Share on other sites More sharing options...
