Material help needed
bharris
You could get a chamfer box (fine fillet) then use a vray light material with a vray dirt (soft falloff) as the texture - for the darker line i would select all edges and make a fine renderable spline with a slightly darker material on it.
or
Use the model and put a vray 2 sided material on it with lights inside hiding the dark edge geometry just inside the box. this might be a bit more difficult to get such even lighting with however.
