sscranton Posted February 1, 2012 Share Posted February 1, 2012 Studio/Institution: Middlebury CollegeClient: PersonalGenre: Residential ExteriorSoftware: 3ds Max, VrayWebsite: http://www.sullivanscrantonstudio.comDescription: I started learning Max/Vray the past three weeks and this is my first project with the software. I want to limit post processing (photoshop) so I'm trying to do all of my landscaping within Max - the trouble I'm having, however, is keeping my polygon count down while still creating realistic terrain. Any tricks of the trade to creating realistic trees/ground while keeping the file light? I still have a ways to go, but I'd love any criticism of the overall compositions. Link to comment Share on other sites More sharing options...
Janwalli Posted February 2, 2012 Share Posted February 2, 2012 if you want to use 3D plants, then there is not much you can do - you will need all the polygons, so that it looks realistic. But usually this is not such a big issue, as long as you make use of instances/proxies. In general I have a problem with sense of scale in some of your pictures. Link to comment Share on other sites More sharing options...
Ivaylo Kondzhagyulov Posted February 2, 2012 Share Posted February 2, 2012 You are Welcome, Shane! Very nice job! It dosen't look like beginner! Link to comment Share on other sites More sharing options...
sscranton Posted February 2, 2012 Author Share Posted February 2, 2012 Thanks for the feedback, I've added some people/landscape objects to give a more accurate scale and I'm on the hunt for some nice trees w/o breaking the bank. Link to comment Share on other sites More sharing options...
stayinwonderland Posted February 3, 2012 Share Posted February 3, 2012 Hail Shane. I have just the thing. Check out Forest Pack Lite. It's the free version of Forest Pack Pro and comes with a dozen or so free HQ trees. If I'm straight up I'll say that your trees look way too '3d'. Your grass could also do with a boost, so what you can do is make a clump of about 5 grass blades, then use max's own scatter to spread those blades over a circle, then use forest pack lite to spread the proxies of those circles in your scene without adding polygons (also, FPL will spread trees around your scene as proxies without adding polygon). It's obviously more complex than this but if you search google for "3ds max scatter" or some such, you'll find a bunch of tutorials. I took info from several and combined them into my own because there are always aspects of tutorials that don't work so you have to patch them together from several tutorials. I made this using the above method: [ATTACH=CONFIG]47108[/ATTACH] Lastly your rocks need some displacement. I find the best displacement is to make a noise material and stick another noise/smoke into the color#1 and color#2 slots. Then add vray displace to the rock and drag the noise into the texture slot. That's more or less the method I used to get this kind of look: [ATTACH=CONFIG]47109[/ATTACH] If you try these, post an update! Link to comment Share on other sites More sharing options...
AubreyM Posted February 3, 2012 Share Posted February 3, 2012 I agree with Andy. Forest Pack, even the free version, is a great plugin. They have tutorials right on thier website that will get you up and running with it in no time. Link to comment Share on other sites More sharing options...
erickdt Posted February 3, 2012 Share Posted February 3, 2012 Hi Shane, When you say that you're having issues with high polygon counts and "maintaining" the lighting that leads me to believe that you're using 32bit MAX. Is that correct? If you have the ability to use 64bit I would strongly suggest you switch to that. It will solve pretty much all of your memory errors which is what I assume you're talking about. Also, in addition to the comments above, I would suggest you use a LWF setup with a gamma setting of 2.2. It appears that you're using a gamma of 1.0 setup which is making your images overly constrasty IMO. You can do a google search or a search of CG Architect to find a myriad of topics and tutorials of about this type of setup. You'll find lighting much easier to control using a LWF workflow. E Link to comment Share on other sites More sharing options...
