illusioncreative Posted February 2, 2012 Share Posted February 2, 2012 Hi guys, I'm currently in the process of producing a visual which I'm doing both a night and day shot for. It's still in the early stages but I'm trying to get the lighting in the pool right. I've attached the image as it is and an example of how I want it to (or think it should) look. I currently have a plane with a fairly typical water material attached to it with some lights shining underneath. Clearly that's not doing the trick... Any advice you can give me on how I go about achieving the effect I'm looking for would be very much appreciated. Cheers, Jamie Link to comment Share on other sites More sharing options...
Devin Johnston Posted February 2, 2012 Share Posted February 2, 2012 The light needs to be illuminating the bottom of the pool along with the water, I don't see any lights in the water so you may have an issue with it not being transparent enough. Link to comment Share on other sites More sharing options...
anejo Posted February 2, 2012 Share Posted February 2, 2012 I think this may help you. http://forums.cgarchitect.com/69928-ugly-shadows-because-light-bouncing-off-water.html Link to comment Share on other sites More sharing options...
illusioncreative Posted February 2, 2012 Author Share Posted February 2, 2012 Perfect! Thank you! Link to comment Share on other sites More sharing options...
Boris Horosavin Posted February 13, 2012 Share Posted February 13, 2012 For effect you want to achieve you can try to use translucency, which means that water needs to have a full mass (not just plane on top simulating water surface.). Also, watch out for IOR. Cheers. Link to comment Share on other sites More sharing options...
