Chris62 Posted February 3, 2012 Share Posted February 3, 2012 My VRay render elements wont save. I check the box "enable" and go thru the list but when I come back to it its unchecked, and no files in the destination folder. VFB is on, the render is saved as a .vrimg and of course the VRImg to OpenEXR untility wont work, I have to open in Max w/ "View Image File" and save out. Im sure Im missing something simple - thanks. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted February 3, 2012 Share Posted February 3, 2012 I dont know much about the vrimg. but just render it without the vray frame buffer and it will be fine. Other than in testing and wanting to see elements, there is no real reason to use it over the max buffer. Link to comment Share on other sites More sharing options...
Chris62 Posted February 3, 2012 Author Share Posted February 3, 2012 I should have kept those two issues separate - but there are several advantages to using the vrimg file, same for VFB. Having said that, still isnt saving render elements. Im using a render service for a large still file for print and Im going over my scene file to make sure Im ready - I need those elements for composite so thats the big issue now. I can live w/o opening vrimg w/ the untility for now. Link to comment Share on other sites More sharing options...
Chris62 Posted February 3, 2012 Author Share Posted February 3, 2012 (edited) Son of a gun - there they are , I just turned off VFB. grrrr... 4 years using vray and I usually save from the VFB. Thanks Corey - you should look into the using VFB - lots of advantages to it. Edited February 3, 2012 by Chris62 Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted February 3, 2012 Share Posted February 3, 2012 Oh good. Yeah the VFB turns them off because they are stored with the render in the VFB which allows you to save them separately. I'm sure there are a lot of avantages beyond test viewing your passes, but I just have never felt let down by the Max buffer. a couple of guys here at the office use it and go straight into PDPLayer which is awesome, but I don't have that installed yet. Anyway, glad your on track again. Link to comment Share on other sites More sharing options...
Chris62 Posted February 3, 2012 Author Share Posted February 3, 2012 The VFB totally escaped me at first and when I discovered the extended capabilities it gives you I was hooked. Lower render times for one, and instant color correction before the render is complete. Link to comment Share on other sites More sharing options...
erickdt Posted February 3, 2012 Share Posted February 3, 2012 Not to thread jack or anything but I was wondering if you guys knew of any method to keep the render elements as layers contained within the "beauty pass" file? I've been saving seperate passes as seperate images for a few years now but it would vastly speed up my workflow if all of the passes could be in the sam layered file. Thanks in advance for your help! E Link to comment Share on other sites More sharing options...
Chris62 Posted February 3, 2012 Author Share Posted February 3, 2012 (edited) Not at all Eric, its all good. Looking for that answer myself right after this post. Check out these threads: http://forums.cgarchitect.com/35047-how-save-multiple-passes-vray-frame-buffer.html http://forums.cgarchitect.com/40802-composite-openexr.html edit..sorry read it wrong. The second link should answer that. Edited February 3, 2012 by Chris62 Link to comment Share on other sites More sharing options...
erickdt Posted February 3, 2012 Share Posted February 3, 2012 Hi Chris, I was hoping to see if there was a way to have all of the render elements come in through Photoshop. At this point I don't use Combustion or Toxic for post. Thanks for the info though! E Link to comment Share on other sites More sharing options...
Chris62 Posted February 3, 2012 Author Share Posted February 3, 2012 Still not working for me though. You have to uncheck enable FB so you cant save while using it. Dont know about the all in one pass. Ill keep looking. Link to comment Share on other sites More sharing options...
