Msamir Posted February 6, 2012 Share Posted February 6, 2012 Hi all, I have this problem which occurs only when I do a project that includes allot of details, splotches appear all over the details even when I use high settings, I do model in Auto-cad and import to max, I use max 2011 and Vray 2.0. I've attached two images for two different projects, any help to solve this annoying issue would be highly appreciated. Link to comment Share on other sites More sharing options...
Ismael Posted February 6, 2012 Share Posted February 6, 2012 Maybe you can try and model some of those details in Max and see if the problem goes away, then it would be the imported geometry the problem. Link to comment Share on other sites More sharing options...
Msamir Posted February 6, 2012 Author Share Posted February 6, 2012 Already did and it didn't change anything same splotches appear again. Link to comment Share on other sites More sharing options...
Ismael Posted February 7, 2012 Share Posted February 7, 2012 Maybe this then, http://renderstuff.com/vray-gi-engines-choice-best-settings-cg-tutorial/ Link to comment Share on other sites More sharing options...
whale Posted February 12, 2012 Share Posted February 12, 2012 It would have been helpful if you had posted the render settings you are using. But i think you can try Adaptive DMC instead of "Adaptivie subdivision". Then increase the Adaptive DMC subdivision to about 16 (depending on your PC capacity) from the default of 4. Link to comment Share on other sites More sharing options...
