zewanil Posted February 8, 2012 Share Posted February 8, 2012 Hello guys I am really stuck trying to mapping that bench so the line of the glueing wood can continued on the side and look real is there a way i can do that ? thanks so much your help P. [ATTACH=CONFIG]47127[/ATTACH] Link to comment Share on other sites More sharing options...
datacrasher Posted February 8, 2012 Share Posted February 8, 2012 switch it to circular Tile it about 4.0 in the U make sure it going in the right direction choose fit, if it's not going in the right direction change the alignment to x y or Z Link to comment Share on other sites More sharing options...
zewanil Posted February 8, 2012 Author Share Posted February 8, 2012 hey thanks for your answer and your time ... where is the the circular tile option ? Link to comment Share on other sites More sharing options...
datacrasher Posted February 8, 2012 Share Posted February 8, 2012 (edited) sorry Cylindrical not circular Edited February 9, 2012 by datacrasher Link to comment Share on other sites More sharing options...
zewanil Posted February 8, 2012 Author Share Posted February 8, 2012 not cylindrical not circular ... than what ? Link to comment Share on other sites More sharing options...
datacrasher Posted February 9, 2012 Share Posted February 9, 2012 Please re-read again you put the dot in Cylindrical and under alignment switch it to either X Y or Z you can tell switch direction the map is point from the P.view and the top view if it's point in the wrong direction then switch map in either the 3 directions tile it about 4.0 once you have done that then click the fit button the map will fit the table top you have some white showing on you're image. you can rotate that down to the bottom where the map is located or use a different wooden material so there is no whites Link to comment Share on other sites More sharing options...
