Victor1423 Posted February 14, 2012 Share Posted February 14, 2012 Why is that? Does it affect the materials? How can i change it back? I installed a plugin and the moment i opened Max and opened the material editor i saw the change and i just want to ask the above questions just to make sure nothings wrong and if there is something wrong how to fix it! Thank you! Link to comment Share on other sites More sharing options...
Michael Parente Posted February 16, 2012 Share Posted February 16, 2012 Do this: - open 3ds max - open the material editor and the environment window (Rendering Menu - Environment) - Check to see if you mistakenly set the Ambient Color Slot to white - Set the ambient color slot to black - Check to see that the material editor is back to normal - Party! - Come here and tell me if that did the trick Link to comment Share on other sites More sharing options...
Fry Posted February 21, 2012 Share Posted February 21, 2012 Thanks Michael, it worked for me, had the same problem. Link to comment Share on other sites More sharing options...
Umesh Raut Posted February 22, 2012 Share Posted February 22, 2012 In addition to that, check if the gamma got changed to a higher value, like say 2.2 from 1 or something of that scale (which you should have manually changed in the first place when started using max , and then check putting some material in the editor and render it applied to something in a scene. If the end's good everything else is. Link to comment Share on other sites More sharing options...
Victor1423 Posted February 22, 2012 Author Share Posted February 22, 2012 In addition to that, check if the gamma got changed to a higher value, like say 2.2 from 1 or something of that scale (which you should have manually changed in the first place when started using max , and then check putting some material in the editor and render it applied to something in a scene. If the end's good everything else is. yeah that was the problem! i fixed it! Thank you all for your help! it was the gamma! Link to comment Share on other sites More sharing options...
