Guest ateebhussein Posted February 18, 2012 Share Posted February 18, 2012 Hi, As I am new with Vray I need some help. My final image is too bright. I used these vray settings http://img836.imageshack.us/img836/9909/11333564.jpg This is my max file http://www.mediafire.com/?6snz9njoihc9wgj Please help!!! Link to comment Share on other sites More sharing options...
AubreyM Posted February 18, 2012 Share Posted February 18, 2012 I don't use Exponential color mapping a lot but I would tun down the "Bright Multiplier". It also may be your lights (sorry I am not going to DL your scene.) If you are using a VraySun make sure the Intensity value is around .015 or so. Link to comment Share on other sites More sharing options...
Ismael Posted February 18, 2012 Share Posted February 18, 2012 Ateeb, Your Direct01 (Your Sun) needs Shadows turned on. That is the main brightness problem. Nest the Vray plane light at the window area, you do not even need it, given the amount of light entering the place from the Sun alone. Maybe turn it off. Here is some homework if you wish: http://www.spot3d.com/vray/help/150SP1/tutorials_interior.htm Link to comment Share on other sites More sharing options...
Guest ateebhussein Posted February 19, 2012 Share Posted February 19, 2012 The light is fine now. But The materials are all the same colour...I dont know why Link to comment Share on other sites More sharing options...
elnaz Posted May 24, 2012 Share Posted May 24, 2012 i ' ve a problem in rendering of my file.. i don't konw why it takes long time? my pc is win7,corei7,ram 4G.. but my file that is the livingroom scene took 8 hours to render whereas my file have 37 mb size.. please help me to reduce my render time at lease one hour Link to comment Share on other sites More sharing options...
