TomA Posted February 21, 2012 Share Posted February 21, 2012 How do you make a material shiny without directly reflecting it's environment? A shiny copper for instance. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted February 21, 2012 Share Posted February 21, 2012 Try using the exit color. For materials like copper if you (not exactly, but close) match the diffuse color and the exit color you can usually get a satifactory balance between shiny and environmental reflection. Link to comment Share on other sites More sharing options...
TomA Posted February 21, 2012 Author Share Posted February 21, 2012 Exit colour? Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted February 21, 2012 Share Posted February 21, 2012 Yes. So in the reflection area of a standard Vray material is a setting for exit color. Once the reflections reach max depth it returns this color. If you set the reflection color to he diffuse roughly, then the exit color roughly the same as well, and lower the max depth, objects will appear from your environment, but all have the same color tone. Check this out: http://www.aversis.be/tutorials/vray/vray_basic_material_settings_01.htm my earlier statement was not a complete answer on how to create the material you are looking for. This should help. Link to comment Share on other sites More sharing options...
Ismael Posted February 21, 2012 Share Posted February 21, 2012 Turn reflections off in the Material Options... http://forums.cgsociety.org/showthread.php?t=713084 Link to comment Share on other sites More sharing options...
