World's simplest question (sorry) ...
chrisclocher
this is a way to do that: you may want to create a customized grid, an object grid actually. go to auxliary tools>grid then create your new grid and either rotate it or align it to an object. go to view>grids to activate your new grid, it should work as a new world axis system.
anyway, objects can be aligned to other ones quite easily. just do this: tools>align (Alt+A). then you can align it to a local axis.
hope it makes sense.
I created a grid, but I cant seem to make the grid rotate to match the object. Whenever I use the align command, the object rotates, but it does not even rotate to match the new grid, only some random rotation. I dont think I even need a grid, after I am done with this box I will not need thes coord's anymore. Is there not a simple way of just rotating the coord to an object? I liked Jennifer's idea but I could not find a "Local" option under VIEWS.
I think Jennifer may have already nailed the question...
Click on the Heirarchy Tab. Under the Adjust Pivot rollout, click 'Affect Pivot Only'
Then under the 'Alignment' group, click Align to Object.
And also, you might wanna scan your help file and or the manual.
