TomA Posted March 6, 2012 Share Posted March 6, 2012 What is the best, simplest and easiest way to export/import/reference dwg files between Microstation and Max so that the origins align perfectly? I can't change the Microstation origins because they are set up for the project I'm working on, and the Max model is already at an advanced stage. Cheers Link to comment Share on other sites More sharing options...
Sketchrender Posted March 6, 2012 Share Posted March 6, 2012 I don't think there is an option, I have the same problem with all Autocad files, the further they are away from the origin the more corrupt the lines become. I dont think it has been solved, and I don't know why either it's been around for a long time now. Short of just moving everything to 0,0,0 in MS, and doing it every time. I hope somebody has a solution, because it is a problem that should be solved from Autodesk and MS side. I brought it up with a Autodesk and they said, and I quote " not our problem". Phil Link to comment Share on other sites More sharing options...
erkutacar Posted March 9, 2012 Share Posted March 9, 2012 i hate it when they do that and why havent they still converted typed commands to easy shortcuts and buttons Link to comment Share on other sites More sharing options...
dande Posted March 15, 2012 Share Posted March 15, 2012 You probably have this sorted. But What I do is save a copy of the drawing. Pick a point on the drawing. Get the coordinates. Shift the drawing to 0,0 from this point. Then when the original microstation drawing changes. Save a copy again and use the coordinates of the move point so you can shift it to 0,0. That way you drawing is always in the same position when you move it. Link to comment Share on other sites More sharing options...
TomA Posted March 15, 2012 Author Share Posted March 15, 2012 Good idea Dan. Another solution is to move a reference file to the correct origin, and when you want to load a different file, copy and replace the previous reference. Philip Kelly - it is very frustrating, but I guess they aren't keen to solve the issue because Autodesk will want to encourage people to buy Autocad rather than use Microstation. Link to comment Share on other sites More sharing options...
dande Posted March 15, 2012 Share Posted March 15, 2012 Tom Going between Autodesk products and Max you have the same problem Link to comment Share on other sites More sharing options...
TomA Posted March 15, 2012 Author Share Posted March 15, 2012 If you use Autocad as your main 2D/3D drawing/modelling package you can directly reference your files into Max and update simply and easily as you go along, whereas with Microstation you have to first export to .dwg, which is a pain to say the least. Link to comment Share on other sites More sharing options...
dande Posted March 15, 2012 Share Posted March 15, 2012 That is true but you still have the origin problem which is a bit silly. You could export FBX from MicroStation and link the FBX file in Link to comment Share on other sites More sharing options...
