Material Editor Missing
TomA
are you sure you have not minized the material editor so it's in the bottom left of the screen?
try deleting the max.ini file it may have corrupted located at C:\Documents and Settings\username/\Local Settings\Application Data\Autodesk\3dsmax - 32bit\enu.
once you have deleted that file then restart you're pc and autodesk will automatically replace it.
Maybe its just off screen for some reason. Here is a script that will reset your all max windows to your current screens upper left corner.
http://www.scriptspot.com/3ds-max/scripts/reset-3ds-max-windows
It wouldn't hurt to try, but all windows will be here the first time you open them. Once you move them away they will stay wherever you put them.
Hope this works.
