rebinkamaran Posted March 14, 2012 Share Posted March 14, 2012 (edited) hi ,, i have a problem with my Vray when i add the reflection layer to the material it does not appear on the material when i do the render i checked every thing i dont know what is the problem i did every thing and it still the same dont know why so help please .... Edited March 14, 2012 by rebinkamaran Link to comment Share on other sites More sharing options...
Roodogg Posted May 1, 2012 Share Posted May 1, 2012 You should be using a VrayMaterial with Vray Renderer. If you are, go to the options tab on the material and make sure "trace reflections" is ticked. If it's not you will only see specular highlights. Also, make sure the value or reflection texture is higher than RGB 000,000,000. If you're still not getting reflections, I don't know! Link to comment Share on other sites More sharing options...
christophergeorge Posted May 1, 2012 Share Posted May 1, 2012 Also having the normals flipped on the faces can mess with vray reflections. Go to monocromatic style and make sure all your faces are white Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted May 1, 2012 Share Posted May 1, 2012 It really could be any of a lot of things.... Is there something in the scene that your material should be reflecting would be my first question? What is your Fresnel setting? Try rendering a Raw Reflection Element. At the very least you will know if the material is set up properly. If it you get a blank pass, it isn't. Link to comment Share on other sites More sharing options...
