vray material not applying to object
andreeam
Well not seeing the material in the viewport could be that you haven't clicked on "show map in viewport" in the material editor.
As for not seeing the material in the render, is there a bitmap that the material uses that is not set right in the material editor? That is one of the reasons I don't use materials from there, it's easier to create them myself, less problems.
Ok, one problem partially solved, thank you, i forgot about the show map in viewport. It shows up in the viewport but not correctly. To give you an example, i should have a stone wall but it appears as a grey wall and this is what happened with a lot of materials. They show up as a one colour material when they should have a texture. :(
The materials are set correctly in the material editor.
Yes , it asks for missing external files.... The program was taking the maps from the wrong place... Thank you very much for helping me. This problem was eating my brain for days now... Thank you again and have a nice day! :)
