zoro Posted September 13, 2004 Share Posted September 13, 2004 I FACE THIS PROBLEM When I apply material to an object the material doesn’t appear in the view port, instead a colure almost same as that material will appear. For example when I apply wood material, you can see in the view port brown color instead of the real map. Help me please. Link to comment Share on other sites More sharing options...
pixelperfectg Posted September 13, 2004 Share Posted September 13, 2004 Be sure to click the "show map in viewport" button on the material editor. Also, your 3d object may need a UVW map applied before it will show the actual material in the viewport. If your not sure where the "show map in viewport" button is, or what a UVW map is, they are both listed in the 3dsmax help file Link to comment Share on other sites More sharing options...
marckie258 Posted September 13, 2004 Share Posted September 13, 2004 hi! use UVW map... then try to render again. MARK MAC Studio Link to comment Share on other sites More sharing options...
Onslaught Posted September 13, 2004 Share Posted September 13, 2004 Make sure you have the actual .jpg or .bmp or whatever image name loaded. Link to comment Share on other sites More sharing options...
zoro Posted September 14, 2004 Author Share Posted September 14, 2004 Dear pixelperfectg ….marckie258…..Onslaught, Thanx for your fast respond …………..I will try your solution. Thanx again. Link to comment Share on other sites More sharing options...
trhoads Posted September 14, 2004 Share Posted September 14, 2004 I took the screenshot above, and circle the icon for "display in viewport" in yellow. Link to comment Share on other sites More sharing options...
