chow choppe Posted March 28, 2012 Share Posted March 28, 2012 Hi everyone my brain is fried trying to find out whats the reason behind this noise over complete animation. please see the top right part render of 11 frames of animation. u can see the gaussian noise over the whole anaiimation http://www.the3rddimension.in/test.avi Only the camera is moving in this so i am using LC and IR method of animation. LC is 2500 samples , flythrough mode, IR is set to mediuom hsph subd at 80 and interpolation samples at 40. AA noise threshold is .007 and adpative DMC tried at 1-16, 1-100 and 1 - 12 with negligible difference. using area filter. Please help. i can play with settings only if i know whats the reason behind that overall noise on animation. Someone must have experienced it before P.S animation rendering at 720 X 576 thanks Link to comment Share on other sites More sharing options...
MaukusKuhlo Posted March 28, 2012 Share Posted March 28, 2012 Hi, you could try setting the noise threshold under vray DMC Sampler to 0.003. this reduces noise. A other possibility to disable reflection on tree leaves if there is some. I hope it wil help you. Link to comment Share on other sites More sharing options...
Devin Johnston Posted March 28, 2012 Share Posted March 28, 2012 It looks more like a flicker to me caused by coplanar surfaces. Link to comment Share on other sites More sharing options...
chow choppe Posted March 28, 2012 Author Share Posted March 28, 2012 Hi, you could try setting the noise threshold under vray DMC Sampler to 0.003. this reduces noise. A other possibility to disable reflection on tree leaves if there is some. I hope it wil help you. tried .003. not helping and since noise is on complete image i am assuming the issue is something else and not reflection of trees Link to comment Share on other sites More sharing options...
chow choppe Posted March 28, 2012 Author Share Posted March 28, 2012 It looks more like a flicker to me caused by coplanar surfaces. there are no coplanar faces there. i just checked again Link to comment Share on other sites More sharing options...
chow choppe Posted March 28, 2012 Author Share Posted March 28, 2012 uploaded the file here. please see whats wrong if someone can. wud be really thankful http://www.the3rddimension.in/archive.rar max 2011 vray 1.5 SP5 Link to comment Share on other sites More sharing options...
MaukusKuhlo Posted March 29, 2012 Share Posted March 29, 2012 tryed to download but it says Bandwidth Limit Exceeded. Link to comment Share on other sites More sharing options...
Umesh Raut Posted March 29, 2012 Share Posted March 29, 2012 tryed to download but it says Bandwidth Limit Exceeded. Same here..... Umesh Link to comment Share on other sites More sharing options...
chow choppe Posted March 29, 2012 Author Share Posted March 29, 2012 yeah trying to sort it out. the bandwith problem. will be corrected soon Link to comment Share on other sites More sharing options...
