fabw Posted March 29, 2012 Share Posted March 29, 2012 Why when I replace vray sky map in enviroment withe jpg bitmap, when I render with the same camera settings my sky is very dark? Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted March 30, 2012 Share Posted March 30, 2012 (edited) I don't know, but a couple of things to check would be: In your Gamma/Lut setting that you tick the "Affect Material Editor" box In Vray Settings Tick "Affect Background" Lastly you can try adjust the "Output" on your map to something more, like 3 or 5 or whatever it takes. Are you setting the map to environment and spherical? There are a lot of things it could be, all are simple, but in what context is it dark? Rendered? Viewport? Both? Good Luck. Edited March 30, 2012 by CoreyMBeaulieu Link to comment Share on other sites More sharing options...
Tommy L Posted March 30, 2012 Share Posted March 30, 2012 You'd be better off compositing the background in post. Leave the vray sky as it will cast light and reflections. Save out to a format that carries an alpha channel, such as targa or tiff, then put your jpeg behind your geometry in photoshop. An environment is only going to be beneficial if it's a spherical map. You can do a horrible fake by wrapping a jpg background around your scene and tiling it, but the 8 bit image will give dull reflections. The reason you are not seeing the jpg is due to exposure. Are you using a physical camera? Link to comment Share on other sites More sharing options...
