MultiSub Texture Scale Problem
toms200
I have a brick texture applied to the large box in the attached image. I have put the same brick texture into a multisub material and applied that to the small wall. What is causing the brick in the multisub texture to render as a flat color?
[ATTACH=CONFIG]47383[/ATTACH][ATTACH=CONFIG]47384[/ATTACH]
and if I may, sometimes in the heat of excitement or hurry (whatever) we tend to forget that multi sub materials need to have their own ids set on the corresponding poly's. Just check that after the uvw co-ordinates are placed properly. Its so simple yet so so common to overlook.
