Physical Scaled Models/ Rapid Prototype
philipnoland
Does anyone have a suggestion for companies that are really reputable for building scale models and also I am looking for a company that is a specialist with 3d Printing. I would imagine someone out there is specializing in this type of Prototyping with Architectural models.
Does 3dsMax output to these 3d print machines well? What are the most important things to consider? I hardly know much about them but would think there are some qualities to look for when choosing a particular method of printing.
Thanks
-Philip
I'm no expert, but I do know your geometry needs to be a closed solid. You can check this by using the STL Modifier. I don't think that the native *.max file will work for 3D printing but *.3ds and *.dwg will do the trick. As for service providers, I can only suggest doing a web search for 'rapid prototyping' or '3d printing'.
Sounds like you have a fun project on your hands... Good luck!
Joel
I wouldn't recommend using 3DS Max for 3D printing (without converter), STL files are the best from MAX but require sooooo much correcting later. The main issue is modeling method itself. If you want to do 3D prints, you should use software that models solids. If you ever imported DWG or DXF to MAX you can get some idea about what i'm talking about (not solids but same errors appear). There are various methods of printing, and they all depend on size and accuracy of the printed object. And for printing itself, for small objects (you're from US so i'll use imperial system) like under 10" in size you get the best quality. Some printers are as accurate as 4 microns (1/66") but i don't think you want that of quality. Just to be sure, check their samples.
I'd suggest this:
1. use software that creates solids, do your work there, STLs will work fine
2. If you still wish to use other software, like 3DS MAX, Autocad, Archicad, w/e... you can try CADspan or similar converting before printing. That way you'll avoid usual errors like hollow spaces, broken edges etc.
As for printing company, you can visit a few that are close to you and check out their samples and get more detailed instructions (if needed).
